Bug in Keil debugger?
Hi guys. I'm trying to simulate a code for MSC1210 (Texas Instruments). The problem is that I have serious doubts about the results of the simulation since I've detected the following situation:
I make an external memory access, which, as you all know, uses the Port 0 as both Address and data bus (the address will be latched to preserve its value for the address lines of the memory). The fact is that it succeeds, in spite of I forced several Port0 pins to LOW, simulating that there is a ground connected to them.
The simulation of this "forcing" is done by cliking the corresponding checkbox of that pins in the "Port0" simulated peripheral window.
I hope you help me. If you need any clarifying note tell me.
Thanks, and excuse my wrong english.
