I use Keil uVision to bulid a target there is no errors and warings.But Rebulid got 4 warinings,like: Warning C280: "ad_ ptr" unreferenced local variable
'Build' processes only those files that hav changed; 'Rebuild' processes all files.
So, presumably, the errors where in files that were not processed by the 'Build'...
Oh, thanks. But how to deal with the warnings, like <unreferenced local varible"size"> What does it mean?
"... <unreferenced local varible"size"> What does it mean?"
That you are nor referencing local variable "size".
"... But how to deal with the warnings, ..."
Reference "size".
#include <Nordic\reg24lu1.h> #include "hal_nrf.h" #include "cklf.h" #include "cpu.h" #include "hal_usb.h" #include "hal_usb_hid.h" #include "usb_api.h" #include "nordic_common.h" static hal_usb_dev_req_resp_t device_req_cb(hal_usb_device_req* req, uint8_t** data_ptr, uint16_t* size) reentrant; static void suspend_cb(uint8_t allow_remote_wu) reentrant; static void resume_cb() reentrant; static void reset_cb() reentrant; static uint8_t ep_1_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant; static uint8_t ep_2_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant; bool ep1_sent, ep2_sent; volatile usb_state_t usb_state; void usb_init(void) { hal_usb_init(true, device_req_cb, reset_cb, resume_cb, suspend_cb); hal_usb_endpoint_config(0x81, 32, ep_1_in_cb); hal_usb_endpoint_config(0x82, 32, ep_2_in_cb); ep1_sent = true; ep2_sent = true; usb_state = USB_AWAKE; } void usb_wakeup(void) { hal_usb_wakeup(); usb_state = USB_AWAKE; } usb_state_t usb_get_state() { return usb_state; } void usb_wait_for_configuration(void) { volatile hal_usb_state_t usb_hal_state; do { usb_hal_state = hal_usb_get_state(); } while(usb_hal_state != CONFIGURED); } void usb_send_packet(uint8_t* in_data, uint8_t ep_num, uint8_t size) { if(ep_num == USB_EP_MOUSE) { while(!ep1_sent) ; ep1_sent = false; } else if(ep_num == USB_EP_KEYBOARD) { while(!ep2_sent) ; ep2_sent = false; } hal_usb_send_data(0x80 | ep_num, in_data, size); } static hal_usb_dev_req_resp_t device_req_cb(hal_usb_device_req* req, uint8_t** data_ptr, uint16_t* size) reentrant { hal_usb_dev_req_resp_t retval; if( hal_usb_hid_device_req_proc(req, data_ptr, size, &retval) == true ) { // The request was processed with the result stored in the retval variable return retval; } else { // The request was *not* processed by the HID subsystem return STALL; } return STALL; } static void suspend_cb(uint8_t allow_remote_wu) reentrant { USBSLP = 1; // Disable USB clock (auto clear) if (allow_remote_wu == 1) { // Enable wake-up on USB and USBWU (bit3:0=1010) // Enable MCU_WU (bit5:4=10 ) on RTC WUCONF = (BIT_5 | BIT_3 | BIT_1); usb_state = USB_REM_WU_ENABLE; } else { // Enable wake-up on USB and USBWU (bit3:0=1010) WUCONF = (BIT_3 | BIT_1); usb_state = USB_REM_WU_DISABLE; } } static void resume_cb() reentrant { ep1_sent = true; ep2_sent = true; usb_state = USB_AWAKE; } static void reset_cb() reentrant { ep1_sent = true; ep2_sent = true; usb_state = USB_AWAKE; } static uint8_t ep_1_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant { ep1_sent = true; return 0x60; // NAK } static uint8_t ep_2_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant { ep2_sent = true; return 0x60; // NAK } /** @} */
warning C280:'adr_ptr':unreferenced local variable warning C280:'size': unreferenced local variable warning C280:'adr_ptr':unreferenced local variable warning C280:'size': unreferenced local variable
Yes. Unused variables are unreferenced. So you get a warning. So your choices are: 1) Make use of them. 2) Remove them (if global or local) 3) Remove name of unused function parameter,keeping just the type as place holder - or adjust the function to take fewer parameters.
"So your choices are:"
Or, like I said,
4) Reference them. For example, the following works for many compilers.
static uint8_t ep_1_in_cb(uint8_t *adr_ptr, uint8_t* size) reentrant { (void)adr_ptr; (void)size; /* Reference unused parms */ ep1_sent = true; return 0x60; // NAK }
I included your alternative in my "use them".
But the important thing is that this is not Keil-specific. It is the same for just about all C/C++ compilers.
That's not quite the same as just referencing them.
"Use them" implies putting them to some functional use - whereas Dan's suggestion just references them without actually doing anything with them at all.
And there's the problem: some compilers will give a warning along the lines of "code has no effect" for such references...
BTW: Is it just me, or does the ARM compiler not warn about unused parameters?
