We are using the Keil C-compiler and uVision when compiling a project for the C166-platform. Latley we have been noticing a strange behaviour of our program. A closer look of the result revealed that a number of variables end up being assigned to the same address. Has anyone else experienced the same problem?
I cant explain why the variables do end up at the same address. There is no #pragama-directive used or any such. The declaration of the variables are as follow:
In the .h-file:
/*## attribute stEventCOMtoPRORxEnd */ extern struct evCOMtoPRORxEnd stEventCOMtoPRORxEnd [MAX_IRQ_EVENTS]; /*## attribute stEventCOMtoPROTxEnd */ extern struct evCOMtoPROTxEnd stEventCOMtoPROTxEnd [MAX_IRQ_EVENTS];
In the .c-file:
/*## attribute stEventCOMtoPRORxEnd */ struct evCOMtoPRORxEnd stEventCOMtoPRORxEnd [MAX_IRQ_EVENTS];
/*## attribute stEventCOMtoPROTxEnd */ struct evCOMtoPROTxEnd stEventCOMtoPROTxEnd [MAX_IRQ_EVENTS];
When looking at the .m66-file after compiling the following can be observed:
1062D2H stEventCOMtoPRORxEnd VAR --- HDATA0 ?HD0?PPROTOCOL 1062D2H stEventCOMtoPROTxEnd VAR --- HDATA0 ?HD0?PPROTOCOL
A third variable (not related) is also assigned to the same address (1062D2)
Actually, all three variables that ended up on the same address acutally had one thing in common.
All of them are arrays. All of the sizes were defined in a .h-file that was not directly included.
So, for some reason the compiler igonerd the fact (didnt even give a warning), that the array sizes were unknown. And later optimezed the output and made all pointers refer to the same address.
Including the correct .h-file resolved the problem.
