Variables end up on same address
We are using the Keil C-compiler and uVision when compiling a project for the C166-platform. Latley we have been noticing a strange behaviour of our program. A closer look of the result revealed that a number of variables end up being assigned to the same address. Has anyone else experienced the same problem?
I cant explain why the variables do end up at the same address. There is no #pragama-directive used or any such.
The declaration of the variables are as follow:
In the .h-file:
/*## attribute stEventCOMtoPRORxEnd */
extern struct evCOMtoPRORxEnd stEventCOMtoPRORxEnd [MAX_IRQ_EVENTS];
/*## attribute stEventCOMtoPROTxEnd */
extern struct evCOMtoPROTxEnd stEventCOMtoPROTxEnd [MAX_IRQ_EVENTS];
In the .c-file:
When looking at the .m66-file after compiling the following can be observed:
1062D2H stEventCOMtoPRORxEnd VAR --- HDATA0 ?HD0?PPROTOCOL 1062D2H stEventCOMtoPROTxEnd VAR --- HDATA0 ?HD0?PPROTOCOL
A third variable (not related) is also assigned to the same address (1062D2)
  • Actually, all three variables that ended up on the same address acutally had one thing in common.
    All of them are arrays. All of the sizes were defined in a .h-file that was not directly included.
    So, for some reason the compiler igonerd the fact (didnt even give a warning), that the array sizes were unknown. And later optimezed the output and made all pointers refer to the same address.
    Including the correct .h-file resolved the problem.
