i am writing a code(in C language) in which i need a delay of the order of few micro seconds. and this delay is not constant, i.e., i am using a variable and i should get a delay of value equal to that variable and it would be of the order of micro seconds.. the minimum value of that variable is 0.5 and max is 150,i.e., the delay would have to be changing from 0.5 microsec to 150 microsec. the inbuilt functions in the AVR compilers are not giving such short delays. i have no knowledge about keil. can any one suggest me a microcontroller for the delay of this order and also, is there any inbuilt function in keil to give such delays?If yes, then what is it? if not then how to get such delays?
can any one suggest me a microcontroller for the delay of this order any that is fast enough e.g. SILabs f12x is there any inbuilt function in keil to give such delays? not in Keil or any compiler I know of if not then how to get such delays? a delay routine written in ASSEMBLER
A delay of 0.5us is too short for you to initialize a timer and wait for it to timeout. With a fast processor, you can have a timer constantly running and then sample the current value and wait until now - start is long enough.
Obviously, you will need a processor that can perform a number of instructions in 0.5us. An ARM or fast 8051 one-clocker should be able to do it but you have to keep your eyes on the possibilities of the timers. The timer must support ticking at more than 2MHz without overflowing in 150us. A fast-running 16-bit or 32-bit timer would do nicely.
If the processor can do this in less than 0.5us then it should be fast enough: - sample current timer value on function entry. - subtract the estimated call/return time for the delay function call. - do at least one loop sampling the timer again and subtract with start value and compare with input parameter.
This might be possible to inline to avoid any call/return times.
As you can deduce from the above, you would probably require 20-50 MIPS minimum speed from the processor to manage the initial setup and still manage the 0.5us minimum delay.
depending on the processor, you don't necessarily have to subtract the current time from latest timer counter; this loop for example wait for 2 milliseconds on an ARM7 at 72 MHz with a clock input of 18MHz. it waits for the hardware timer to automatically stop when the timeout elapses. changing the constant 36363 yields shorter/longer delays.
// 2 millisecond delay // use T1, MR1 for delays T1TCR = 2 ; // stop and reset timer T1MCR = 0x20 ; // stop timer when value in MR1 reached T1MR1 = T1TC + 36363 ; T1TCR = 1 ; // start the timer while ( (T1TCR & 1) == 1) ;
Yes, but the question is if the setup code wouldn't increase the initial setup time and affect the minimum MIPS required to correctly handle the 0.5us case.
It also makes sure that the timer can't be used for anything else in other parts of the application. If using an arm with 32-bit timers, a free-running timer at 18MHz would turn around every 238 seconds so it would be suitable for other parts of the application that may need up to a few minutes delay.
