Interrupt problem = using External Interrupts
I am trying to use External Interrupts in a program where I have already several active interrupts and modules.
It happens that after I make the pin description for this external interrupt, any of the VIC interrupts occur anymore?!?
GPIO_InitStructure.GPIO_Direction = GPIO_PinInput;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; //lines 8 and 9
GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ;
GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable; // HERE IS THE PROBLEM!!
GPIO_Init (GPIO5, &GPIO_InitStructure);
So if I use IPConnected enable the interrupt stop working, if I use disable the external interrupt doesn't work properly.
After reading about it, it looks that there is a error in the library according to the errata and ST sugest us to use a Dummy_handler:
void Dummy_Handler(void)
VIC0->VAR = 0xFF;
VIC1->VAR = 0XFF;
void VIC_InitDefaultVectors(void)
VIC0->DVAR = (u32)Dummy_Handler;
VIC1->DVAR = (u32)Dummy_Handler;
But for me still doesn't work.
Does anyone have a clue what is going on??
  • Hello Milton,
    I would like to take the opportunity that you are working with external interrupts to tell you that I have a problem with them. I have connected a keyboard to P7 port. The problem is that the interrupts are launched two times: when I press the key and when I release it.
    Have you had the same problem any time?
    Thanks in advance.
  • Hello Milton,
    Thanks in advance.
