Variable mapping to address
I use uVision IDE and arm-gcc toolchain for my lpc2129 board.I mapped the CAN standard filters to an area in memory:
#define StandardFilter[2] (*((volatile unsigned long *) 0xE0038000));
However in my main program the follwing syntax seems to be incorrect:
StandardFilter[0]  =       0x20012002;//this is line no.57
StandardFilter[1]       =       0x20032004;
because the compiler throws the following error:
CAN_RX.c(57): error: parse error before '[' token
Could someone tell me what the correct syntax is?
Thank you.
