I am utilise Watchdog Timer to reset when something goes wrong, but I found that watchdog in LPC2138 is not reliable. Does any one has issue with Watchog Timer in LPC2138?
The following is my Setting at start of program:
WDTC = 0x01FFFFFF; // Setting Timer WDMOD = 0x03; // Reset and Interrupt WDFEED = 0xAA; // Sequence Feeding WDFEED = 0x55; // Sequence Feeding
Then every interval one second feed the watchdog as follow:
WDFEED = 0xAA; WDFEED = 0x55;
The problem is watchdog reset un-reliable. The following is the log: Ext,Last Reset:20 Feb 2009 10:36:43 WDT,Last Reset:20 Feb 2009 10:43:29 WDT,Last Reset:20 Feb 2009 10:48:47 WDT,Last Reset:20 Feb 2009 10:54:05 WDT,Last Reset:20 Feb 2009 10:59:23
Above log data is in my application that trace current situation. Ext is external reset just after down load program in device. WDT is reset because of Watchdog timer.
Is there any idea or errata note regarding watchdog timer?
Rudy
Best way to check for errata is if you download the errata document for your processor.
By the way - do you disable interrupts around the two feed assigns?
I see you did take a closer look at the documentation while I wrote my answer. But are you sure that it is enough to just block task switches? Shouldn't you disable the interrupts?
