I am using the STR912FA44 and I am implementing a CAN communication module. I got an CAN example that uses the following uController clock configuration which works fine:
SCU_MCLKSourceConfig(SCU_MCLK_OSC); // 25Mhz SCU_PCLKDivisorConfig(SCU_PCLK_Div2); // 8Mhz SCU_PLLFactorsConfig(128,25,4); // 16 Mhz SCU_PLLCmd(ENABLE); SCU_MCLKSourceConfig(SCU_MCLK_PLL);
It happens that I would like to use a different Pclk, once this clock is used for other modules, but if I change this values the module simply stops working ... my question is, Is there some kind of limitation concerning the Pclk in CAN module? Has to be 6 Mhz? I went though the ST documentation and I found nothing ...
Thanks for your help!
