[b] i'm new user of lpc2378. and i'm doin project on interfacing graphical lcd with lpc2378..i'hv an developement board....and i'm using keil compiler..can anyone give me C codes for glcd..plss
I have recently downloaded and successfully used one of the samples of embedded artists. go to www.embeddedartists.com/.../oemindex_2478.php (you may to register first) where you can find WORKING source code for GCC compiler (I have just rather easily converted it to RV). not getting an LCD to work is frustrating (I know...) so I wish you good luck. remember that you may need to adjust the parameters of the on-chip controller to meet your hardware needs! ergo: you still must read the data sheet...
"you may to register first"
You will - otherwise that link just gives a blank page.
Start here instead: www.embeddedartists.com/.../
[b]....hey...neil...i've completed my project...... and i dnt hv ny prblm with my keyboard....n i can spell evrythng verywell..its depend on ur common sense...and my development board is working greatly....
swell.
well....thts my style....u wont get it..leave it bro..n mind ur own business rather thn finding mistake in spellings......
f 1 dnt wnt d wk 2 cm ndr pblc scrtny, dnt pst 2 pbl plc!
Your style?
If it is your style to be a young fool who can't blend in, then you are the looser since the people who can help you will just ignore giving any help.
A bright person adjusts his flock behaviour depending on the current flock. Right now, you are doing the baboon style. It works best when you are with other baboons.
[b]..yeah..with baboon like u...just doing the perfect thing....
The [b] didn't give bold text the first time you tried. Not this time either. Maybe with more attempts...
Pratiek,
I just wonder what people who know you shorten your name to.
Might it simply be Prat?
...guyz guyz guyz...that's enough i think.....dont you have any work than replying useless craps here...just do that work whatever for you...OVER...
