ARM: I am trouble :Some time coade work and sometime not
Dear all
Here I am in trouble due to unexpected performance of my LPC2378.
I am using keil uVision3 compiler and LPC2378 processor.
My code is working some time properly all result i am getting correctly but some times processor hangs and not comes out even after resting hardware and downloading the same code again.
Code size is only 14Kb.
It is comming out only when I downloading different code.
what happling I am not getting.Is there any stack related issue or ? or something else?...
regards
Shyam T.
Pune India
  • Does it matter if you download using JTAG or with FlashMagic?
    Does the sample applications work?
    What differs between your code and the sample applications?
    Is it your hardware, or a reference board?
    Have you done any attempts to pinpoint how long the application runs before failing? Are you sure that the application is downloaded ok?
    Your post doesn't really contain much information.
