hello sir i have 8 bit data which is coming from ADC0808 this is taken into the AT89c51 micro controller via port P0 now i want to transmit this serially so i have to place data into SBUF (for this please send the C code)....
and after that i received some data serially into SBUF now i ahave to show this data on port P2( for this please send the C code)
i used this code:
SBUF=P0 /// to transfer port dat into SBUF P2=SBUF // to transfer SBUF data into port 2<pre/> but it is not working
There is plenty of exaple code ready & waiting for you in the downloads area of this very site
See also:
RS232 guide for 8052 users: www.8052.com/.../120308
8051 Tutorials: www.8052.com/tutorial.phtml
the so-called "bible" for the 8051:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
Books about the 8051: http://www.keil.com/books/8051books.asp www.8052.com/books.phtml
You do not need new code.
You need to understand already available sample code.
How do you know that you have a valid value from the ADC?
How do you know that the serial port is ready to transmit a new character?
HowÂ'do you know the serial port has a character to pick up?
You do not need code, but to spend a bit of time understanding how things work - if you don't, then you will not understand new code either. And your professor will expect you to understand the code you turn in.
<b.sir
here i am sending the detailed code see it and tell the correction
#include<reg51.h> void serial_init() { TOMD=0x20; SCON=0x50; TH1=0xfd; TR1=1; } void main(void) { unsigned char var; serial_init(); while(1) { while(!RI); RI=0; ACC=SBUF; val=ACC; SBUF=val; while(!TI); TI=0; } }
but i am not able to send data correctly into SBUF and not extracting data from SBUF into any other regioster
please help me in code i tried in so many fashions but failed
