Hi
i want to learn rtos and i am not beginner at this . also i read the book . but that describe only CO-OPERATIVE SCHEDELULER . it is useful but for pre-emption ( like RTOS ) has no information .
I visit freertos.org and i read Fundermentals . but i need for more ! . it became more sophisticated even using rtos . there are many function . on the other ands creating and using task,tcb,semaphore ... are very difficult to see . can any one help me using rtos or give me detailed informaion on ... ?
There are no "the book" and no "the rtos".
If you need help using an RTOS, then you must specify exactly which RTOS you are having problems with. And books are best if written for this specific (RT)OS.
About semaphores etc. The concept is identical for all OS. The API and parameters may vary a bit, but a semaphore works conceptually the same in Windows as it does in any of the RTOS you may be able to find.
