Hi: I comply my program can such error message appeard"indirect call , parameter do not fit within register" what this mean.
This message appear becasue I define an function pointer in a structure and use the function in the main routine. The program is as below:
int aaa(int x,int y) { int z; z=x+y; return(z); }
typedef structure{ short i; int (*aaa)(int x, int y); } bmp085;
bmp085 tmp_bmp085;
main() { int abc; int a=1; int b=2; bmp085 *t_bmp085=0; t_bmp085=&tmp_bmp085; abc=t_bmp085->(*aaa)(a,b); // error }
why the error occur?
Thanks for your replying!
Jason
hi, put your code in
and
so that it will be readable OK, taling about your problem, we need to assign function pointer with some other function eg: void *fn();//declare fn1(); //some other function fn = &fn1;//function assignment and then use it
bye
take care
Place source code source code between pre and /pre
