can i get the c code for different RAM test algorithms like Checkerboard test algorithm March test algorithm Walk path test algorithm Galpat test algorithm Transparent Galpat test algorithm Abraham test algorithm
"can i get ..."
Can you use an Internet search engine?
Also search for "Michael Barr" - he has an excellent article on memory testing, with specific emphasis on embedded systems.
It tells you all about the physical failure modes in memory systems, so that you can understand what the tests are actually looking for - and why some simplistic tests are worthless!
