Keil Programming
Hi everyone,
I am using XC164CS microcontroller. I need some help in keil programming. The operating frequency is 20KHz. The condition is that if the Vin= 0 volt the duty cycle=5% and if Vin=5V then duty cycle= 95% and duty cycle should be vary in between 0 to 5V range. I manually connected 0 to 5V resistor to the CAPCOM pin to check the condition and how quickly it measure.
I have one idea about after every interrupt the voltage level change and duty cycle also change but difficult to find in programming.
Any ideas or thoughts?
Vivek
