Hello
I am facing a problem in the following code.
code :-
#include "LPC318x.h" void IRQ_HANDLER(void) __irq { PIO_OUTP_SET = 0x7EFFFFFF; PIO_OUTP_SET = 0x7EFFFFFF; }
int main (void) { unsigned int i=0; SYSCLK_CTRL = 0x00000140; HCLKPLL_CTRL = 0x00014024; UARTCLK_CTRL = 0x0F; MIC_ER = 0x000007C0; U5LCR = 0x03; U5CLK = 0x0000020E; UART_CLKMODE = 0x00000550; U5FCR = 0x00; U5IER = 0x07; U3DLL = 27;
while(1) {
U5THR = 0x55; U5THR = 0xAA; }
When i enable UART5 interrupt by using MIC_ER interrupt is generated as it should be. But after transmitting the data it jumps to an unusual location 0x000002d4. But it doesnt go to IRQ handler. If i don't enable the interrupt using MIC_ER then it executes only while(1) loop. The main aim of the program is to blink the LED after send data through UART5 as mentioned in the IRQ interrupt handler.
Thank You,
Ankit Thakkar.
hello
I checked again. It was my fault. It enters into interrupt mode as the interrupt is generated but it doesn't find any interrupt handler at the location. I checked in the map file that IRQ_Handler is assigned an address in the memory map. As it doesnt find any IRQ handler it goes into ABORT mode. I need to add IRQ handler at the location assigned to IRQ_Handler in the map file. But i dont know how to add that IRQ handler. Let me know if any body familiar with this kind of problem.
Regards,
Ankit thakkar.
I haven't worked with any LPC31xx chips, but the LPC21xx and 23xx chips has special VIC control registers where you assign the pointer to the interrupt handler.
If you just look at example code for your processor, you should find a number of examples where an interrupt handler is defined, and where the interrupt controller is configured to know where the interrupt handler is located. The command "grep" is your friend. If you can't installed a "grep" application on your machine, to quickly google for a Win32 version and install. It helps when you want to quickly scan example code or header files for specific details.
sorry for bad code posting. you are right that interrupt vector itself is an array of addresses but when it enters into IRQ mode it loads program counter by the starting address of IRQ routine. which is LDR instruction. I have placed breakpoints on that instructions. So when it enters into IRQ mode it should load PC by IRQ routine starting address. But it doesn't execute the instruction. again i m posting the code where i placed the breakpoints in startup file
Vectors LDR PC,Reset_Addr LDR PC,Undef_Addr LDR PC,SWI_Addr LDR PC,PAbt_Addr LDR PC,DAbt_Addr ;DCD ||Image$$ER_IROM1$$RO$$Length||+||Image$$RW_IRAM1$$RW$$Length|| DCD 0x4000 ;PHYTEC comment: This hard codes the size ;that the secondary bootloader uses to copy ;binary software to SDRAM. LDR PC,IRQ_Addr LDR PC,FIQ_Addr
And i placed breakpoints when CPSR is changed when it enters into IRQ mode and loads SP.
Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #IRQ_Stack_Size
i have placed breakpoints on all the points as shown in the code. but PC doesn't even enter in that code.
Does the address after LDR match the address of your IRQ handler as seen from the map file?
Have you tried to add breakpoints for all the other vectors?
HEY when i place more than two break points in the program and try to run it. it executes code upto first break point but then the execution stops there. it doesnt go ahead by pressing F5. Even it doesnt go ahead if i press F10 or F11. Thats strange. When i debug step by step using F11 it doesnt execute using F5. I am doing onchip debugging and ETB module of LPC3180 supports upto two breakpoints at a time only. So i dont reach on the exact address location where IRQ starting address is located.
Much can be done with only two breakpoints.
You may have to run the application multiple times, trying different locations for your breakpoints.
hey i checked that whether my interrupt is routine is called from interrupt handler or not. Its working. Interrupt handler defined in start up file calls function which i have defined in the source code. I checked it by manually executing instruction at interrupt handler in startup file. Now problem remains that when IRQ is generated does Program counter goes to interrupt handler defined in the start up file or not. I am trying for this.
I run code from external SDRAM. when IRQ is generated program counter jumps to some location in IRAM. i dont know how data is moved from external SDRAM to IRAM. So i cant come to know where my interrupt vector table is stored in IRAM.
it is exceedingly difficult to understand what's wrong without a clear understanding of HOW your system is organized. how does it boot? what is the logic behind the bootcode? memory available? without minimal topology details - I doubt whether anybody would be in a position to help. give more details in concise, technical language.
yeah sure.
My code is in external SDRAM which starts from 0x80000000. In the starting of my code interrupt vector table is located then all functions are stored. In my code i defined an IRQ handler function. Which should be called when IRQ is generated. But When IRQ is generated it goes into onchip IRAM (0x00000000 to 0x00004000) instead of going into IRQ handler function. I have verified that if program counter goes into interrupt vector table it calls the desired function. So the problem is that when IRQ is generated why program counter doesnt enter into interrupt vector table.
in case of an IRQ, the processor is supposed to go to 0x18 - which must contain the instruction to just to your function. is that the case?
in meant, of course , "jump to your function"
no. I have stored the whole code in SRAM. And the map file shows the location of IRQ handler function is 0x800001a4. But it doesnt jump to the location 0x800001a4 when IRQ is generated. LPC3180 doesnt have vectored interrupt controller. It contains one main interrupt controller and two sub interrupt controller.
What happens when you single step past the code? do you get the registers bold in the window?
In simple step past memory is updated as it should be. Even in single step everything goes well but when IRQ is generated program counter doesn't jump on IRQ routine while executing in single step. keil doesnt offer simulation capabilities for lpc3180 so its a pain to check memory values everytime.
I managed to enter into the interrupt vector table when IRQ is generated. I mapped IRAM to 0x00000000. At startup interrupt vectors are located. But It doesn't jump to the desired location. Instead of that if i execute LDR PC,[PC,#0x0018] from external SRAM it jumps to the desired location but if i execute this instruction at the remapped location 0x00000018. It doesnt jump to the specific location. Does anybody have any idea?
THANKS GUYS... I MADE IT WORKING FINALLY..
please, tell us what the problem was?
