uV3 cannot change number base using menu
I recently upgraded my uV3 to 3.62c. When I right-click over a variable in my watch list, a drop-down menu appears with a "Number Base" item. Neither of the two options (hex or decimal) work.
If I add the base to the variable name (e.g. "tempvar,10" or "tempvar,16") the base is displayed correctly. While this works around the problem for watched vars, it does not help the display of all my locals (which can not be modified).
My older version did not have this problem. Has anybody else seen this behavior?
If it matters:
IDE-Version:  µVision3 V3.62c
Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2008
Tool Version Numbers:
Toolchain:        PK51 Prof. Developers Kit  Version: 8.16
Toolchain Path:    C:\Program Files\Keil\C51\BIN\
C Compiler:        C51.Exe       V8.16
Assembler:         A51.Exe       V8.01
Linker/Locator:    BL51.Exe      V6.15
Librarian:         LIB51.Exe     V4.24
Hex Converter:     OH51.Exe      V2.6
CPU DLL:           S8051.DLL     V3.63
Dialog DLL:        DCYG.DLL      V2.55
Target DLL:        BIN\SiC8051F.dll       V2.7.0.0
Dialog DLL:        TCYG.DLL      V2.56
