Hey Guys, I am writing to my micro's flash one byte at a time using that APP note from NXP (AN10342_1), I saw that it is possible to write a page at a time. How do I go about writing a page at a time?
Thanx :)
Xarion
Now, why do you ask questions without even mentioning what processor you are using? Do you think NXP has produced one and only one processor model?
Youw to program it? Don't you think that the NXP datasheet has the requested information?
The cited application note includes this information in its title.
As it happens, the datasheet does not have the requested information.
Your contributions are usually high quality, please leave the newbie baiting to the idiots.
hey guys, thanx for the posts, i managed to find some info, just got a quit q, after i write a byte to flash, should i wait a couple of milliseconds? i know this is really a keil related question :/
thanx again :)
No. If you had referred to the data sheet, you would have known more about the timing requirements of writing to your flash, and how you can verify whether a write operation has succeeded.
But an interesting thing with application notes, is thaty they can be relevant for a number of processors.
But if you want to go one step further than the app-note, you may have to know the specific processor and look at a very specific datasheet.
If I google for the relevant app-note, the links suggests that the app-note is relevant for: P89LPC906/907/908 P89LPC912/913/914 P89LPC9401 ...
In the end, I don't know if the OP can find the answers in any datasheet or not. Possibly. Possibly not. But without knowing what chip, I will be unable to know what datasheet.
The trend these days seems to be for the datasheet to cover only the stuff that is unique to the processor or small group of processors that it applies to. This is often a subset of the features that are common to an entire family (or series, or whatever) of processors, these tend to be covered in 'application' notes, as is the case here.
In some cases the datasheet sometimes seems to be little more than the marketing brochure in a serious looking font.
I agree. I have encountered several such cases. Very annoying indeed!
NXP tends to have quite good documentation.
But note that they often call their documentation of the functionality "User Manual". They contain information about how the different modules works, and bit descriptions for SFR.
Then they may have a datasheet that instead focuses more on power consumption, rise and fall times etc. I.e. a document intended more for a hw designer, while the user manual is mainly intended for the sw designer.
But whatever subdivision that has been made between different documents - without knowing the exact chip number, you can not know exactly which documents are applicable. And you can't know what errata that may be important. Many chips from the same family may seem almost identical, but be of different age, i.e. many of the errata from the earlier released siblings having been closed, but at the same time new errata may have cropped up.
Then they may have a datasheet that instead focuses more on power consumption, rise and fall times etc. I.e. a document intended more for a hw designer, while the user manual is mainly intended for the sw designer. the divison as I see it is that the UM is a family datasheet and the datasheet states what is unique to the family member.
At least for the ARM chips, the UM does contain a lot of "only for xx" information, including the pinouts, part id codes, ... Basically everything a sw developer needs, with the exception of the ARM documents about the core and instruction set.
It's just the ordering codes, electrical information (limits, static, dynamic, ADC precision...), temperature limits, mechanical tolerances, ... that are missing from the user manual.
And the datasheets can have download names such as datasheet/lpc2364.lpc2365.lpc2366.lpc2367.lpc2368.pdf which clearly indicates that they are just as family-wide as the user manuals.
The datasheets looks like "sell-in" documents, with a lot of bulleted lists with all features of the chips - something for an NXP application engineer to bring to a customer meeting to describe why the customer should select a specific chip or family.
So in the end, it can lead to quite interesting times if a developer only gets the datasheet or only the user manual. Best practices always requires that a developer scoups up all documents (and sample code) that are available on the producers web site and quickly scan through them to figure out which documents that are applicable.
In some situations, that isn't enough. The needed information may be missing but possible to deduce from the manuals from other processors (even from other families) from the same manufacturer.
