LPC2368 bootloader and RL-ARM
I developped an usb bootloader which works perfectly when I use an simple firmware, but which doesn't works with an firmware using RTX kernel.
Anyone can help me ?
  • You need to supply more information.
    Are interrupts enabled/disabled when you start your application?
    Are you in supervisor mode or user mode when you start your application?
    Exactly what happens/doesn't happen?
    Does the RTX application work ok if linked to start address 0, i.e. used without a boot loader?
