I developped an usb bootloader which works perfectly when I use an simple firmware, but which doesn't works with an firmware using RTX kernel.
Anyone can help me ?
You need to supply more information.
Are interrupts enabled/disabled when you start your application?
Are you in supervisor mode or user mode when you start your application?
Exactly what happens/doesn't happen?
Does the RTX application work ok if linked to start address 0, i.e. used without a boot loader?
My RTX application works perfectly, it's the RTX_Blinky demo project.
Exactly what happens/doesn't happen? It goes to the SWI_Handler
SWI_Handler B SWI_Handler
Thanks for your help.
The problem is that the default LPC2368 behavior is to look for interrupt vectors table in the start of the flash (0x40000000). Specific, The RTX application go there every OS switching (to SWI_handler).
But in your case the vectors table that reside in flash beginning is the bootloader one, not the one of RTX Application.
To resolve this problem, you have to add the following options to the Startup File (LPC2300.S) of your application, in Options - Asm - Define : RAM_INTVEC REMAP RAM_MODE
Now the startup procedure will copy the interrupt vectors table to the RAM and will look for it there. (I hope that your startup file version recognize all these options, if not I copy that in message end).
Additionally, you have to change memory area for application in Options for Target -> Target -> Read\Write memory area to start from 0x40000100 and contain only 0x7F00 (possible lower, but this for safty). So, the application will leave the vectors table RAM untouchable.
Code for LPC2368.S Insert if not exist before stack setup for each mode:
; Copy Exception Vectors to Internal RAM --------------------------------------- IF :DEF:RAM_INTVEC ADR R8, Vectors ; Source LDR R9, =RAM_BASE ; Destination LDMIA R8!, {R0-R7} ; Load Vectors STMIA R9!, {R0-R7} ; Store Vectors LDMIA R8!, {R0-R7} ; Load Handler Addresses STMIA R9!, {R0-R7} ; Store Handler Addresses ENDIF ; Memory Mapping (when Interrupt Vectors are in RAM) --------------------------- MEMMAP EQU 0xE01FC040 ; Memory Mapping Control IF :DEF:REMAP LDR R0, =MEMMAP IF :DEF:EXTMEM_MODE MOV R1, #3 ELIF :DEF:RAM_MODE MOV R1, #2 ELSE MOV R1, #1 ENDIF STR R1, [R0] ENDIF
Ok, it works now. Thank you very much
This is strange, I still dont understand why this is occurring.
1. The new code that I download (using my bootloader via USB) is built with the RTX kernal.
2. If my bootloader is built with an RTX then I can boot the new code correctly.
3. If my bootloader is built without an RTX then Im unable to boot the new code.
4. Both bootloaders (with or without an RTX) will execute code (that contains no RTX) correctly.
In both cases the new code starts at address 0x5000 and has the correct options in the startup file.
Any ideas why?
I used the code USB secondary ISP bootloader for LPC23xx from NXP, it does not work with RTX os.
How I can fix? please help.
Moshe, I am working on a USB bootloader not operating with the presence of RTX. Please see here for a short description of my problem: http://www.keil.com/forum/docs/thread14069.asp I don't understand why using on chip peripherals prevents the application code from being interrupted. I see that the jump to application works, but if I dare to do it with a timer running of USB - the application will not get interrupted. the weird thing is that older revision of the code did not have that, but I don't see how a simple change in startup in main() can give me such a headache. Any ideas?
Mark, I have the same issue. Have you managed to solve the problem?
