A bug in C51 code generation
I think Keil C51 version 8 has a bug in the code generation. The following source shows the bug:
typedef unsigned char BYTE;
typedef unsigned short WORD;
#define FIXED_VAULE     64
#define MAKEWORD(h, l)  (((WORD )(h) << 8) | (BYTE )(l))
void main(void)
    BYTE    x = 2;
    BYTE    y = 2;
    WORD    z;
    // The code generation for this line is incorrect
    z = MAKEWORD(FIXED_VAULE - x - 1, FIXED_VAULE - y - 1);
    // The Keil v8 asm listing shows the generated code for this
    // line is different to the previous line's.
    z = MAKEWORD(FIXED_VAULE - 1 - x, FIXED_VAULE - 1 - y);
    // However, if MAKEWORD is defined as:
    // #define MAKEWORD(h, l)  (((WORD )(h) << 8) | (WORD )(l))
    // the ASM code for 2 lines are the same.
