Hi, I'm using a MCB2300 with LPC2368 and the DNS_demo program. But I can't get the DHCP client and DNS Address from TCPNET working. How could i experiment? Thanks!
This is Debug information: DNS Resolver Demo Example
Resolving host: http://www.google.com ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 ETH ERR: Local IP address: 0.0.0.0 DNS Resolver Timeout expired, Host Address not resolved. DHCP ERR:Timeout for retransm. too big, Next state INIT
From the log it is obvious that the ethernet is not working, because nothing is received.
Did you check the ethernet cable? For connection with a LAN switch you need a straight-through cable. Some of the LAN switches also have an Auto MDI/MDI-X crossover detection and are able to work with both crossover and straight-through cables.
If there is no problem with the LAN cabling, then there must be a problem with your MCB2300, which needs a repairing.
Franc
