I am using cc2430 for inerfacing with a sensor for which I need to activate and start the timer. I tried to program the timer but the count value is not getting activated. Since I am a beginner in programming I request any one of you to show me the program for configuration and start of timers in cc2430 which is using enhaunced 8051 processor.
The probability is quite high that Toshiba can help you - have you visited their web site?
On the other hand, are you sure that you can't use a generic driver?
If all else fails, use the Keil compiler to write your own driver. After all, that is why you ask on a Keil forum, isn't it?
I need MOdem Driver For Xp My Modem Driver name Toshiba satellite pro 6100
CAn any one help me
Why not the reverse - you post your code, and check what feedback you will get on it?
