I am using cc2430 for inerfacing with a sensor for which I need to activate and start the timer. I tried to program the timer but the count value is not getting activated. Since I am a beginner in programming I request any one of you to show me the program for configuration and start of timers in cc2430 which is using enhaunced 8051 processor.
Why not the reverse - you post your code, and check what feedback you will get on it?
I need MOdem Driver For Xp My Modem Driver name Toshiba satellite pro 6100
CAn any one help me
The probability is quite high that Toshiba can help you - have you visited their web site?
On the other hand, are you sure that you can't use a generic driver?
If all else fails, use the Keil compiler to write your own driver. After all, that is why you ask on a Keil forum, isn't it?
