Hello, I am trying to check if addresses bus and data bus are well configured in my external RAM memory. I have done this algorithm
#include <XC164.h> #define low_adress 0x400000; #define high_adress 0x410000; #define high_data 0xFF; #define low_data 0x00; void main (void) { static double idata j,i,k; int xhuge *DIR; DIR = 0x400000; /* DATA BUS TEST */ for (j = low_adress; j <= high_adress; j++) { *DIR = 0x55; // I write 0101 0101 if (*DIR != 0x55) P3^3 = 1; // If what I have read is diferent to what I have written, I switch on an alarm *DIR = 0xAA; // I write 1010 1010 if (*DIR != 0xAA) P3^3 = 1; // If what I have read is diferent to what I have written, I switch on an alarm DIR++; } /* ADRESSES BUS TEST */ DIR = 0x400000; for (i = low_adress; i < high_adress; i = i + 0xFF;) { for (k = low_data; k < high_data ; k++) { *DIR = k; DIR++; } }
but the compiler throws errors. My RAM memory is mapped from 0x400000 to 0x410000 (64kB). Why does the compiler throw this errors?
Build target 'Target 1' assembling START_V2.A66... compiling PruebaRA.c... PRUEBARA.C(17): error C25: syntax error near '=' PRUEBARA.C(17): error C25: syntax error near ';' PRUEBARA.C(17): error C25: syntax error near ')' PRUEBARA.C(20): error C25: syntax error near 'if' PRUEBARA.C(20): error C25: syntax error near 'P3' PRUEBARA.C(20): error C25: syntax error near '=' PRUEBARA.C(22): error C25: syntax error near 'if' PRUEBARA.C(22): error C25: syntax error near 'P3' PRUEBARA.C(22): error C25: syntax error near '=' PRUEBARA.C(24): error C25: syntax error near '}' PRUEBARA.C(29): error C25: syntax error near 'for' PRUEBARA.C(29): error C7: compilation aborted Target not created
John, have a look at this article: www.embedded.com/.../0007feat1.htm
Thanks for your reply, This is one of two codes published in Tamir's page:
typedef unsigned char U8; /* Set the data bus width to 8 bits. */ U8 memTestDataBus(volatile U8 * address); { U8 pattern; for (pattern = 1; pattern != 0; pattern <<= 1) { //Write the test pattern. *address = pattern; //Read it back (immediately is okay for this test). if (*address != pattern) { return (pattern); } } return (0); } /* memTestDataBus() */
In this code I have some questions:
1-.How can I know if *adress pointer is located in off - chip ram and not in on - chip ram?
2-.How can I know at what adress exactly goes this pointer?
John,
surely that information is available to you are you know your hardware.
I'm not sure I understand, but why would you care where in memory the pointer if stored? Is it not that you only care about where it points to?
There is one little issue to think about.
The test is destructive, so if the address pointer is stored in the tested memory region, bad things will happen. Same thing if the test is performed over the stack.
If the address parameter is stored on the stack or not is of course a question of compiler and processor.
Hello, Ihave done the following code:
#include <XC164.h> typedef unsigned char U8; /* Set the data bus width to 8 bits. */ U8 memTestDataBus(volatile U8 * address); U8 idata j; volatile xhuge *pointer; void main (void) { ASC0_CON = 0x0011; // load ASC0 control register ASC0_BG = 0x0011; // load ASC0 baud rate time reload register ALTSEL0P3 |= 0x0400; P3 |= 0x0400; DP3 |= 0x0400; //set direction register ASC0_TXFCON = 0x0100; /* transmit FIFO is disabled */ /// ASC0_CON |= 0x8000; // enable baud rate generator j = memTestDataBus(* pointer); ASC0_TBUF = j; //Send me a memTestDataBus function result through ASC0 while (1); }
I have also a compiler warning:
Build target 'Target 1' assembling START_V2.A66... compiling PruebaRA.c... PRUEBARA.C(19): warning C40: 'int' converted to 'xhuge' pointer linking... Program Size: data=581(near=581) const=12(near=0) code=470 creating hex file from "PruebaRAM"... "PruebaRAM" - 0 Error(s), 1 Warning(s).
The value of "j" is 0x01.(First position). Does it mean that the memory is bad installed?
The memtest function expects to receive an address. Not as an integer, but as a pointer to a memory cell.
You don't send a pointer, since you use the * to pass the value the pointer points at. That will not get your memtest function to do what you think it does, or more specifically it won't test the memory cell you think it does.
Another thing:
You don't specify a type for the data the pointer should point at. The compiler will default it to be a pointer to int. Was that what you intended?
Finally: You never assign your variable "pointer" a value, so it will be zero-initialized when the program starts. Whas that what you intended?
I recommend that you get a good book on the C language, and take a closer look at pointers and pointer indirection. And until you are very comfortable with pointers - and everything else about the C language - you should consider all warnings as if they where errors. The probability will be very high that the compiler is correct, and that it has caught a real problem.
Thank you very much Per for your reply :) The truth is that it was a lapse of concentration. Those errors were my mistakes. I have fixed the code in this way.
#include <XC164.h> typedef unsigned char U8; /* Set the data bus width to 8 bits. */ U8 memTestDataBus(volatile U8 * address); U8 idata j; volatile U8 xhuge *pointer; void main (void) { pointer = 0; ASC0_CON = 0x0011; // load ASC0 control register ASC0_BG = 0x0011; // load ASC0 baud rate time reload register ALTSEL0P3 |= 0x0400; P3 |= 0x0400; DP3 |= 0x0400; //set direction register ASC0_TXFCON = 0x0100; /* transmit FIFO is disabled */ /// ASC0_CON |= 0x8000; // enable baud rate generator j = memTestDataBus(pointer); ASC0_TBUF = j; //Send me a memTestDataBus function result through ASC0 while (1); }
It's now ok?
Anyway the problem is still the same.
Are you sure you want to pass a null pointer to 'memTestDataBus'? Besides, what do you need the variable 'j' for?
How do you know that the pointer is null? The pointer points at 0x00000 adress. How to check it?
What I want to do is to point, for example, at first adress of my external RAM, but I don't know how to do it.
I simply use the variable "j"to store the value that 'memTestDataBus' function returns and afterwards to send it through ASC0.
ASC0_TBUF = memTestDataBus(pointer);
Will send the result without the use of a variable.
The datasheet (and possibly your external connections) should tell you where the memory is and how large it is - if your project doesn't know where the memory is, the compiler + linker will not be able to produce a project that makes use of the memory as expected.
But I want you to once more think about one important issue: If you let the memtest function test a memory cell that is used for stack or for storing any of your variables, you will not get the expected result. The function call may not even return.
Don't try this stuff at home, or in your product! :-)
ASC0_TBUF = memTestDataBus(&memTestDataBus);
Here is my Memory mapping: img160.imagevenue.com/img.php
And here the indicated adresses y my project img133.imagevenue.com/img.php
In order to verify that a pointer does not point at a null address, such a test can be used:
if (pointer) { // this code is executed if pointer is not null } else { // this code is executed if pointer is null }
Note however that Per comments are very much in place: even if a pointer is not null, is does not mean that it points to an address on which you can run your test. running the test might destroy data/code, just like demonstrated in my previous post.
#include <XC164.h> #include <intrins.h> #define ASC0_TINT 0x2A typedef unsigned char U8; /* Set the data bus width to 8 bits. */ U8 memTestDataBus(volatile U8 * address); volatile U8 *pointer; sbit MY_OUT = P1L^0; void main (void) { DP1L = 0x0001; // load direction register pointer = 0x400000; // the pointer points at 0x400000 adress if (pointer) { MY_OUT = 1; // this code is executed if pointer is not null } while (1) { ; } }
Tamir, with this code, MY_OUT is to 5V, therefore,as you can see, the pointer isn't null
What else can I do? Thanks ;-)
what is the problem, again?
pointer = 0x400000;
indeed points 'pointer' to a non-null address.
