Hi!!
I have a basic code under RTX51, read/write serial port. Without RTX51 control it work ok. But if i use RTX and download my project to the target it dont work.
I have saw the example code TRAFFIC, and i include all different files: RTXCONF, RTXsetup, STARTUP. I modificated anyfiles to put xdata, and to select my micro but i dont know why dont work. Im looking similar examples but i cant find the solution...
My micro is AT89C51ED2. Any idea??
I guess you will be willing to pay AGAIN, javi, if you are desperate enough?
Does the traffic example work on your target?
Then either base your application on the traffic code, or spend more time comparing the differences. Have you tried with a smaller application? First a main() that doesn't start any new tasks. Then add one task. Then a second. Programming is all about splitting a problem into pieces small enough for you to be able to handle.
