We are redoing an 87C51FB design with the 87C51MC2, which is readilly available from DigiKey. The problem is, the -MC2 is an OTP part, and we have a lot of code development to do yet. This is going to kill off a lot of parts before the coding is finished. So, we identified a FLASH part for this, the AT89C51RE2SLSUM, a PLCC44 part, which should do the job nicely.
BUT, after a week of fruitless search, the -RE2 is proving nearly impossible to find. Even Atmel won't supply samples, they refer us to DigiKey. DKey doesn't have any, and they require a minimum order of hundreds, as does everyone else who doesn't have them in stock. We found one distributor who would sell us just two for a premium price, but they're stock is in Hong Kong, so charge $200 shipping! Another distributor will supply two or three, but they won't have any until mid-July!
So I come here in the hopes someone can either suggest a known source with stock in the US or who can sell us a couple out of their stock, right here, right now. We will pay a premium, of course, within reason.
Thanks for your attention, kenjj
.. is the P89C669
You need check the datsheets to see if it will do (I think so)
Thanks for the speedy response.
The -669 was one of the chips we looked at originally. The -669 doesn't have the second UART, while the -RE2 does. This is a big deal to my employer. Also, it's being obsoleted. I've checked the data sheets on both. The -RE2 has the same pinout as both the -FB, which is what we're replacing, and the -MC2, which is our target for production. The -RE2 is just for code development, but we need something that is essentially the same. I didn't check the data sheets for all these, my engineering employer did, so here I am. If someone knows of a problem with these selections, please let us know!
Later! kenjj
Also, it's being obsoleted I am aware of that, but for development which is to go to another processor, that should not be a problem.
I would check a bit better to make sure Arghmel has copied the MX technology well enough.
If you do not have MX in the Arghmel chip, state so and possibilities will pour out.
Thanks for the input, Erik. I have no idea if Atmel did an MX core clone. That's for others to determine. my criteria are: - pin-out compatible with 87C51FB - PLCC44 package - two UARTs - PCA - FLASH with 32k or greater I've checked NXP, Atmel, Winbond, SiLabs, and others. Let the suggestions pour forth...
As for the -669, I stand corrected. It does have two UARTs. Where it differs is in the pinouts. My employer prefers a drop-in replacement for the -FB. Or, as close to drop-in as possible. Thus, the -MB2/MC2 or -RE2. He did limited testing with the -MB2 last year and deemed it suitable. Now he wants to get two of the -RE2s so he can evaluate that for possible development for future designs. And, who knows, we may go all-FLASH.
So, I'm still looking for two AT89C51RE2SLSUMs. Anyone?
Thanks for the input, Erik. I have no idea if Atmel did an MX core clone. That's for others to determine. Then why are you using a MX chip as replacement, (the only advantage of a MX chip is the 23 bit addressing of external memeory)?
my criteria are: - pin-out compatible with 87C51FB - PLCC44 package - two UARTs - PCA - FLASH with 32k or greater I've checked NXP, Atmel, Winbond, SiLabs, and others. but have you searched the Keil device database
http://www.keil.com/dd/parm_search.asp
I just did it and said to myself "that can't be true" and found that the database bas a boo-boo that if you specify flash 32k or greater you gtet virtually no chips, just specify "don't care" for the flash size and scan manually.
Yes, I checked the same night I posted this originally. And, I selected 32k or greater at the time, so I redid the search as you suggest, with no preference for mem size. I got the same answers now as then. I can't use the first two chips, they are not PLCC44. And - Ta!Da! - the other recommendations are the -MA2/MB2/MC2 (all OTP) and the -RE2, which I have already mentioned in the post. There seems to be nothing new under the sun for this.
So, does anyone have two AT89C51RE2SLSUMs?
Thanks for the attention. kenjj
erik
there is 'a million' uPsds and, if you can, for development go 3v3, the LPC952
There may be millions, I'd like to see what criteria you used for your search. If I drop PCA channels from the search I get gobs of choices. And out of those gobs, it's still the same four suitable candidates: the -MA2/MB2/MC2 and the -RE2. But I don't get to choose, my employer made these choices. I lobbied hard for the -952, everything we have on the product would be in the MCU, and it's $2.46 in qty/one!! But I got shot down, he wants a 87C51FB clone (preferably), with two UARTs and more mem space. The -MB2/MC2 fits the bill, and the -RE2 gives us FLASH.
So, my criteria are to start with a 87C51FB in PLCC44 packaging and add two UARTs. Thus: -87C51FB pinout -5V -PCA channels -two UARTs (or more) -FLASH 32K or more (for this go-round) If anyone has any suggestion(s) for suitable alternatives using these criteria, please let me know.
Otherwise, does anyone have two AT89C51RE2SLSUMs?
Thanks for the input so far. kenjj
Ceibo, Nohau, Lauterbach ... more
that will be a much better development environment anyhow.
sorry about suggesting chips without what you had not said you needed.
Thanks for the suggestions, so far, Erik.
I'm hardly the resident programming expert. I'm aware that there are virtual environments available to build code in. My employer, however, has 10s of 1000s of lines of well established code existant, and an established code-testing methodology he is comfortable with. More power to him, lots of pay checks will attest to his ability to produce sellable products. Not that he's hide bound, he has adapted new parts and methods before, but he knows what he wants and needs, and it will take something supplying an undeniable advantage to make him leave his comfort zone.
And the comfort zone is a great place to be. kenjj
it will take something supplying an undeniable advantage to make him leave his comfort zone he might not take my word for it, but an ICE is "an undeniable advantage" for development and there is no need to "leave his comfort zone" in order to buy an ICE. The end result is the same (you do not do final test with the ICE plugged in)
Dear Kenjj,
Who is the distributor in Hong Kong of AT89C51RE2-SLSUM in stock? Thanks,
Lidio
Sorry, I can't say. I'm at home today and all the contact info is not at hand. Besides, I tossed all the previous search paperwork almost two weeks ago, which includes that info. The web searches I did found a couple of sites with thousands in stock.
I remember I contacted AERI.com (RFQ), and Arrow Electronics at (408) 453-1200. I have a note on my calender at work to call a salesmen in mid-July about a shipment they were expecting of these. He claimed (two weeks ago) they had 374 left to sell after deducting orders already placed. Just now I've tried a couple of Google searches and perused the Atmel distributor's info, and nothing jogs my memory that way. I'm back at work Sunday, and will try to find references to the search info. How many are you looking for?
Sorry I can't help just now. kenjj
Thanks for your reply.We are needing 250 units. After developing a new product during 3 years, we realize it was a bad choice component. We had some dificulties with AT89C51RE2-SLSUM it is true but we thought it would be resolved in time by ATMEL.
