hi,
i'm using uVision3.33 , uC-80c31x2. my question is: I'v initilize buffer array which is been loaded with 24 Byte each interval time. now i want to shift the all array right/left by 1 bit. maybe an example will clarify bettet:
unsigned char array_1[24]; unsigned char array_1[24] = { 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24};
the array's values in the example are just for example. probably the operand '>>' must be use. the result i wish for is: (shifting all the array right only one time)
unsigned char array_1[24] = { 0x00,0x81,0x01,0x82,0x02,.....,0x92};
thanks in advance.
