processor busy after erase command
Hello
in our sistem we have the necessity to refresh an external Watchdog-Chip, by toggling one OUTPUT-PORT each 160ms.
Unfortunately, that must occours also during flash-erasing (...)
Well, our bootstrap code makes a copy of both Erase AND Watchdog-Manager code into PSRAM.
This is my code :
  HVAR (IO_BYTE, 0xC000AA) = 0x80;
  HVAR (IO_BYTE, 0xC00054) = 0xAA;
  HVAR (IO_BYTE, adr)      = 0x33;
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  do
     FSH_ptrWTD_Process (); //<-manage watchdog-refresh
     fsreg.v = HVAR (unsigned short,FSR);    }
  while (fsreg.b.busy);
I see that between the excecution of
and the first excecution of FSH_ptrWTD_Process () , there is a delay of about 110 ms, that is the erase timing.
The problem is, that such time could be till 500ms, bigger that our watchdog refreshing time(160ms).
On the Infineon manual xc164_um_v2.1_2004_03_sys.pdf I found " Read accesses to the Flash module are delayed until command mode is terminated."
I am sure that no flash accesses are contained in the watchdog management.
Did I make (see) something wrong or simply there is no chance to avoid this delay?
Data:
uP = XC164CS16F20F
Model = Medium
Bye and thanks in advance,
Federico
