hello friends, my project for final year engineering is not working, i m doing project which needs interfacing uc 8051 with pc and bluetooth module CX81400/CX72303 i am totally helpless with this one please help me if u find some time for me. thanks in advance!!
and say just "my car is not working" I am sure he will know exactly what the problem is.
specifics!!!
sorry i didn't get u
how can anyone help you when you do not say WHAT the problem is. That "it is not working" can be any of 1.452.611 reasons.
what have you done? which part of th code seems to be the problem? (show that code) how does "it is not working" show?
or - is this a veiled attempt to make a fried pigeon fly in through the window (i.e. write code code for me FOR FREE).
ok if u r intrested to help me, then here i want to send u my project details pls give me ur email address thanks for reply!
look, I don't think that anybody here is going to actually write the code for you. why don't you just post the most critical parts that are problematic (according to you) and let us judge?
you be thinked that sir erac will give the email yes????
no. erac is kind and strong and wise and knowledgeble but no having time for sillly help!!!
you be looking at his wise answers he giving you before and you reed it.
wise words of wisdom::: do not try to running before walking yes.
sir erac is a busy lord and needs his peace time.
please tell me that is it possible to interface bluetooth module with uc8051 and also using port 1 as input and port 2 as output
you think the postings you give is funny yes?????
who is the board with processor?????
sir erac not be wanting the blue tooth and he is sore!!!
"please tell me that is it possible to interface bluetooth module with uc8051 and also using port 1 as input and port 2 as output"
In your final year, you should be able to deduce the answer yourself - or have you been sleeping instead of listening to the teacher and doing all your homework?
It isn't exactly rocket science to figure out what requirements your bluetooth module requires, and compare with the available signals on the processor.
Since you say that your final project is not working, you must already have spent time with this - wasn't making sure what hardware to use and how to connect them the first step in your project? You can't develop any software until you have figured out how to connect the different parts!
first - kalib rahib stop busting everybody's balls! come on! what are you, a KGB guy?!
now, as to the question: please check out www.tdc.co.uk/index.php
this is a serial blue tooth module - so the answer to your answer is - YES !
port1 is being quasy directionel pins yes.
so is being can used for inputs and outputs. good.
port2 is for external memery accessing you be knowing and the ansewr is which hardware you having use???
Thanx for the help sofar.
I Tested the .HEX file it was working nice.And i now made the keil to create the WM Project.It was giving the outof RAM message because by default the keil places all const into RAM,So i could fix it.
I would like to have a similar design for cpua + T6963.Could you some one help me out please !!
1.How to change or write our own LCD driver ? 2.What are the macros to be configured ? 3.What are the files to be excluded or included ? 4.What are the functions to be modified ?
Thanks in advance
proton
