Strange Interrupt leads to Abort Mode
I've got a unexpected problem with Interrupts.
Would be nice to discuss it.
I use Timer0 to have about 16000 fast interrupts (FIQ) per second.
There is a AD-Conversation and a few lines of long long int aritmetic to compute. Inside this FIQ-routine there is a static counter. When it reaches 16000 it is reseted and a Software interrupt (SWI) is generated every second.
The SWI-routine has do to some computations and then to display it all on a special three wire conected display.
The programm does not work with 16000 Timer0 Interrupts per second.
It is terminated by Abort-Mode. This comes a little unexpected to my. The effect is gone if i turn down FIQ frequency downto 100Hz. Is it possible that interrupts create a stack overflow?
Should i post my code?
  • How do you expect that your SWI will be finished in 1/16000th of a second, i.e. when it is time for the next FIQ? Remember, you only have 62.5us in total for both FIQ and SWI.
    You only require one result/second to be displayed, so why not let your main loop handle the display output whenever it sees the flag that the FIQ has collected 16000 samples?
