hi. i am trying to read out some memory using uVision socket interface and UVSC_DBG_MEM_READ. the result is UVSC_STATUS_SUCCESS, but in fact there is not data returned. UVSC_Tester.Exe seems to have the same problem (AMEM.aBytes is empty).
does anyone have a working example of reading out memory using UVSC_DBG_MEM_READ?
The Socket interface is relatively new. Which version of uVision are you using and what is your target DLL?
we are using uVision3 V3.60 and BIN\UL2ARM.DLL V1.37 as target DLL (according to About uVision...).
as a workaround for the problem described earlier, we use a loop and UVSC_DBG_CALC_EXPRESSION to read out memory byte by byte, which performs well.
Hi Andre,
Which device are you targetting?
Thanks, Richard
hi richard!
we are simulating the Philips LPC2292.
bye,
andré
I have checked the UVSC_DBG_MEM_READ command with an LPC2294 both in simulation and and on a real hardware target, and have found it to work correctly. I performed this testing using the UVSC Tester V2.05.
Please update to the latest RealView MDK available at http://www.keil.com/update/rvmdk.asp and then contact support.intl@keil.com if you are still having an issue with this.
Best Regards, Richard
