Hello all,
void select_next_task(void) { if (l_task == 0) { l_task = 1 ; } else { l_task = 0 ; } } __asm void context_switch(void) { STMDB R13!, {R0-R12, LR} ; save context BL __cpp(select_next_task) ; select the next task to run LDR R0,=__cpp(g_task_stacks) LDR R1,=__cpp(&l_task) ADD R0, R0, R1 ; calculate the offset of the next task stack LDR R13, [R0] ; set the stack pointer to the new stack LDMIA R13!, {R0-R12, LR} BX LR ; embedded assembly requires an explicit return instruction }
I am trying change the context of my STR9. For that, I am working on a small prototype that I will extend later. The problem is that the marked like generates the following linker error:
scheduler.axf: Error: L6238E: context_switch.o(.emb_text) contains invalid call from '~PRES8' function to 'REQ8' function select_next_task.
If I comment the marked instruction, the program links corectly. I know what this is all about: assembler code (that does not preserve 8-byte stack alignment) calls compiled C/C++ code (that requires 8-byte stack alignment). But why is this caused only when I try to load SP with another address? Is this the proper way to do it? Are there any restictions on the address contained in SP?
ok, I guess I cannot just set the address of SP. i'll try something else like copying the next stack over it. please let me know if you have any comments!
