When using member-function-pointers I noticed that they have a size of 8Bytes each. However when I ask the compiler it says it is only 4Bytes. Having a couple of objects in you program which have member-function-pointers and are created dynamically with new will allways crash your program.
Please refer to the following source-code and documentation:
#include <StdIO.h> #include <Reg164ci.h> /* A simple external object */ class cCalculator { public: int calculate(); }; int cCalculator::calculate(){ return 27; } /* The description of the member-function-pointer */ typedef int (cCalculator::*fptr)(); /* An object with an array of such member-function-pointers which is able to call these functions by an index. */ class cAnObject { public: cAnObject(); ~cAnObject(); fptr fptr_array[2]; // 2 x 8 bytes = 16 bytes (see watchwindow) int member1; // 2 bytes int member2; // 2 bytes // -------------------------------------- // total: 20bytes = 0x14bytes }; /* The constructor */ cAnObject::cAnObject() { member1 = 1; member1 = 2; } /* The destructor */ cAnObject::~cAnObject() { member1 = 0; member1 = 0; } int main (void) { // now we have the external object cCalculator calc1; cCalculator calc2; // and a couple of objects containing some function pointes cAnObject test1; cAnObject test2; cAnObject test3; fptr memberfunction = &(cCalculator::calculate); test1.fptr_array[0] = memberfunction; // here we get the size of our objects (see watch window) volatile unsigned long object_addr1 = (unsigned long) &test1; volatile unsigned long object_addr2 = (unsigned long) &test2; volatile unsigned long object_sizeA = object_addr2 - object_addr1; volatile unsigned long object_sizeB = sizeof( test1 ); //... // please notice that the static objects have a distance // which is different from its size ? why? // count the bytes and you see the sizeof() is wrong !! // now we simply create the dynamic object (with the wrong size), why ? compiler ? // which here leads to an -access violation-, due to // the wrong calculated size of the function pointers cAnObject * p_test4; p_test4 = new cAnObject; // and set the function p_test4->fptr_array[0] = memberfunction; // calc the size volatile unsigned long objectSize4 = sizeof( (*p_test4) ); // ---- // now the function call itself cCalculator * p_calc; // here we select our target object p_calc = &calc1; // do the static object call by an index == 0 fptr p_fct1 = test1.fptr_array[0]; int x = ( (p_calc)->*( p_fct1 ))( ); // now use the other object p_calc = &calc2; // do the dynamic object call by an index == 0 fptr p_fct4 = p_test4->fptr_array[0]; int y = ( (p_calc)->*( p_fct4 ))( ); // if there is any time please notice that there is a second bug: // try to remove the line "fptr p_fct4 = ..." // and put it into one line like " int y = ( (p_calc)->*( p_test4->fptr_array[0] ))( ); " // and your whole program will crash ! // just print the result printf("%d = %d \r", x, y ); while (1); }
Sven, Some of your assumptions are unfounded. As Hans-Bernhard Broeker noted, you cannot assume anything about the placement of objects - it depends of quite some factors, including the optimination level. In addition to that, do remember that compiler tend to patch structues/objects to have a size that is a power of 2, so that iterations offsets can be easily calculated using shifts. This and other factor may contribute to the observations you made. Please refer to your map file for complete details.
I understand the preceeding comments from Hans-Bernhard Broeker and Tamir Michael as question of how can I be sure that the linker puts both objects into the memory as I assume it does.
(1) As mentioned, you can count both objects byte-size and you figure out its distance is the correct size. But this is not the point!
(2) You can create two objects dynamically with new at once, where you get two pointers which actually point to the correct starting of the two objects (note that there is an addtional space for the mem-manager of 6bytes -> Kernighan & Ritchie). Then write to the second-object member-variables "member1" and "member2" and the "fptr_array" and watch the contents of the first object. You will see your written variable-data in the first object not in the seconed as you did!! Coincidence? And there are rules of how dynamic memory is allocated and manged -> Kernighan & Ritchie. There are no rules that allow modifying one object which automatically manipulates another. (As far as I know).
(3) This behavior shows up only if you use member-function-pointers or arrays of it in objects which you create dynamically. (note the -access violation- while creating the object.)
As I noticed, the normal function pointer has a size of 4bytes however the member-function-pointer has a size of 8bytes. When you rise your array size count from nr=2 (fptr fptr_array[2]) to anything else you will see there is allways a difference of 4bytes x nr not 8bytes x n.
You are right this was what I also expected but it is not a typo!. This is really what I was looking for. Note that this only happens when your objects have members that are member-function-pointers or arrays of it.
You are on it!
(By the way I can send a screenshot)
As this has come now to a final comon understanding of what is actually wrong with the sizeof(), do you see any way of how to deal with it?
It hasn't. You've made all kinds of claims without much back-up fact.
To go all the way back: how did you arrive at the conclusion that static member function pointers occupy 8 bytes? The compiler, which really should know, clearly thinks otherwise. It stores your object in 12 bytes, and an array[2] of them in 24, when you said one of them must be 20 bytes. I.e. if something's wrong here, it's not sizeof() as such. It goes deeper.
You made wild claims about malloc() storage overheads --- but nowhere in you code do you even call malloc(). Nor do the books by K&R have any relevance to C++'s operator 'new'.
You stated completely wrong things about distances of unrelated variables in memory, too. Please be aware that inspecting values of (presumably) unused variables in a debugger generally proves diddly-squat.
What you really need to do is isolate this into a minimal, broken testcase, and present it to Keil tech support.
Well then:
Arriving in the debugger watchwindow I can see 8bytes for each member-function-pointer in the array, what is for me proof enough. If the debugger says it is 8bytes then "I assume" it is correct.
Now we can come to the malloc. As far as I know a simply new is in EC++ this:
void *operator new(size_t size) { void *ptr; if (size == 0) size = 1; ptr = (void *) malloc (size); if (ptr == NULL) { __abort_execution (ec_outofmemory); } return (ptr); }
--Basically a malloc with a given size. And malloc() is actually Standard C or is this only an assumption?
As malloc doesn't know anything about the object to be created it relys on the given size. This is why size needs to be calculated the correct way. In my example my object has a size of (sizeof()) 0xc.
Whenever I take a pointer p0 as proposed by "Per Westermark" and then take the next object (*p1 = p0+1) the compiler itself calculates the offset for "+1". As seen in the test results between p0 and p1 is a distance of 0x14. Although malloc would give 0xc the compiler would expect the next object after 0x14. Depending on whatever is after 0xc in the memory it is going to be overwritten.
@Per Westermark: You are right "Kernighan & Ritchie" only stated that there is management overhead for a value of the current object size and a pointer to the next empty memory-space. But I noticed that in C166 it is 6bytes. What can be evaluated by simply getting two pointers from malloc.
As shown with the testcases above we have a simple testcase without an answere.
Note that the debugger and the compiler are two different things, so if a bug is involved, the debugger may also be in error. Or the compiler may produce correct code but incorrect debug information, and thereby fool the debugger.
I still do not like your output for p0+1 which does show a _negative_ size...
Is there a difference between values you get with the debugger, and values you get by letting the compiler-generated code print sizeof(), and actual addresses? That should tell if the compiler do produce invalid code.
About memory allocation: Some heap solutions will allow you to perform two allocations and compare the two pointers to deduce the amount of memory used for book-keeping and aligning (as long as the heap isn't fragmented). Some heap solutions - such as the buddy-system - may allocate fixed-sized blocks of "semi-random" location, and may only need a (separately stored) single bit to keep track of allocated/free memory pages. The address and/or the subdivision level to reach the memory page will imply the size of the memory block.
That is why I wrote that the only thing you do know about a returned pointer is that it has at least enough alignment for the data, and that it points to an area of at least the requested number of bytes. If there are any hidden data structures before the returned address is unknown. If there are any extra bytes at the end of the block (because of padding, paging, ...) is unknown. This may also change between two versions of the runtime library, so the programmer may never make any assumptions based on previous experience. Not even if the second allocation will allocate a memory block at a higher or lower memory address.
by Per Westermark Is there a difference between values you get with the debugger, and values you get by letting the compiler-generated code print sizeof(), and actual addresses? That should tell if the compiler do produce invalid code.
Yes there actually is. When I use the sizeof() in the debugger it says 0x14 (the distance of the two pointers p0 and p1). Please remember that I tried to create two dynamic objects where a write to the second object had overwritten data in the first object. When writting to the first object which is at the end of my memory pool and run the simulator I recived the -access violation- error. And indeed the "map" command of the debugger shows that a write beyond the allowed area took place.
As you stated I noticed a difference between the internal library sizeof() and the one which is executed via the debugger.
Thanks for your help on this.
Oh sorry, that actually was a typo. I probably was too enthusiastic. You are right, it is of course not negative its vice versa (but the same values!):
correction
cAnObject c; cAnObject *p0 = &c; cAnObject *p1 = p0+1; >> p0 = 0x10fac >> p1 = 0x10fc0
There are no internal library sizeof() function. sizeof is an operator (not a function and it doesn't need any parentheses) that works with meta-data, and the compiler will calculate all size information directly when compiling based on the type information.
The debugger, on the other hand, will have to look at the debug information generated by the compiler to produce it's information.
If the distance between two objects in an array is 12 bytes (0x0c) but the distance when stepping a pointer is 20 bytes (0x14) then the compiler is most definitely broken!
The sizeof operator must always produce the same value as the distance between two elements in an array, which has to be the same as the amount a pointer is incremented to step one object forward/backward.
This is why a pointer of a base-class type may not be used together with arrays of objects - the compiler would not know how much to increment the pointer to reach the next element. It would assume the size of the base class.
Possibly it comes from the difference between linker and compiler. The interesting point is that the array from above (cAnObject array[2];) has elements which have a distance of 0x14 although sizof says it has only a size of 0xc. So this basically doesn't matter if you have static objects. But creating them dynamically causes errors due to the wrong internal sizeof.
"The interesting point is that the array from above (cAnObject array[2];) has elements which have a distance of 0x14 although sizof says it has only a size of 0xc."
I don't know how to read this sentence.
You said ealier that the size of a two-element array was 0x18 (24), which was twice the size of a single element (12). This should imply that the distance between the elements was 12 bytes, the same as sizeof gives.
Where did you deduce that the distance between two elements in the array was 20 bytes? Note yet again that the debugger may be in error. If so, it may say that the distance is 20 bytes and show broken data in the second element.
Sorry. I try it again.
You proposed to crate an array (cAnObject array[2];), where the sizeof said it has a size of 0x18 so a single object has a size of 0xc. (see testresults1)
Now the strange thing: When I create two pointers of cAnObject which point to the first and the second element of the array, their difference is 0x14. Which is the same thing you figured out with the testresults2.
But 0xc != 0x14. What underlines your theorem: The sizeof operator must always produce the same value as the distance between two elements in an array, which has to be the same as the amount a pointer is incremented to step one object forward/backward.
You you continue to claim "So this basically doesn't matter if you have static objects. But creating them dynamically causes errors due to the wrong internal sizeof."
If the compiler does not use the same offset when doing array[1] or p0[1] or *(p0+1) it really doesn't matter if you have static or dynamic objects. The compiler would not be able to produce correct code for static arrays either.
The question here is still: Have you produced a complete set of figures from the compiler, i.e. without gleaning info from the debugger windows?
Well I recived the variable-data from the watch-window, which includes (size_obj1 >> 0xC, size_array >> 0x18, >> p0 = 0x10fac, >> p1 = 0x10fc0 ).
Is this ok?
@Hans-Bernhard Broeker:
While reading this post I can say you are right, I claimed a couple of things which aren't backed up correctly. After hours of searching for the failure in our program I thought to have a rough understanding of what is going on, so I took the assumptions from experience what might be wrong. But I also noticed there is a missbehaviour of the compiler/linker/debugger or what else. So I proposed the code example from above. Which obviously didn't bring it to the point.
Finally I support the post: If the distance between two objects in an array is 12 bytes (0x0c) but the distance when stepping a pointer is 20 bytes (0x14) then the compiler is most definitely broken! as this is actually true, what can be seen in the testresults1/2.
Probably there is time and you can copy and paste the code from above and follow the idea for yourself. I think its worth trying it.
Thanks.
