while combining C & assembly instructions, how do i assign value contained in any register like r6, r7 etc. to variable defined in C. i did this is it right?
unsigned char myvalue; # pragma asm mov A, myvalue add A, R6 mov myvalue, R6 #pragma endasm
plz tell me....
Ashutosh tiwari Bangalore
http://www.keil.com/support/man/docs/c51/c51_ap_ctoasm.htm
Generally, you don't. What you're trying to do there goes against the grain of a higher-level programming language.
if the variable defined in C is in external memory other than internal 256 bytes, how can i access it in the assembly code written between C code using directives? or is there any way to access directly the register like R6,R7, A,B etc. in C outside assembly code? plz send if there is any solution.
thanks and regards, Ashutish Tiwari Bangalore, India.
