Wrong linker ZI data symbols
I'm linking my code without the use of a scatter file. As a constrain, I'm using the default region symbols
        IMPORT ||Image$$ER_RO$$Base||
        IMPORT ||Image$$ER_RO$$Limit||
        IMPORT ||Image$$ER_RO$$Length||
        IMPORT ||Image$$ER_RW$$Base||
        IMPORT ||Image$$ER_RW$$Limit||
        IMPORT ||Image$$ER_RW$$Length||
        IMPORT ||Image$$ER_ZI$$Base||
        IMPORT ||Image$$ER_ZI$$Limit||
        IMPORT ||Image$$ER_ZI$$Length||
The RO and the RW symbols are correct. The Image$$ER_ZI$$Base is reported correct, but the Image$$ER_ZI$$Limit is the same as the Base and, as a result, Image$$ER_ZI$$Length is 0.
At linking, I get the following message:
Program Size: Code=118868 RO-data=9832 RW-data=2456 ZI-data=206072
So there is ZI data.
Why are the two symbols, Image$$ER_ZI$$Base and Image$$ER_ZI$$Limit, equal and what can I do to correct this?
Thank you!
