I modified the mcb23xx web server example. In the network configuration, I deselected the ethernet module and selected the ppp module. I modified the code in the main program. I removed the dhcp code and added the ppp_listen function. I configured the Windows XP computer as described in the help system. I encounter the following problems: 1. IP address is not auto assigned - if I set fixed IP address the authentication and registration works. 2. When I try to connect to the embedded web server the loading process is very slow and if I click on the action lables the embedded server hangs up.
Before I spent a lot of time debugging the problem, may I ask if someone else probably knows what the problem is?
Thank you, Frank
