hi i'm using Keil U vision IDE 3. i'm trying to implement my logic. but it i'm receiving error as: error: #513: a value of type "hc_ed *" cannot be assigned to an entity of type "volatile ulong *"
when i implemented this code in turbo c i haven't recieved any error.
does any one know how to deal with this problem.
code is:
#include <stdio.h> #include <stdlib.h>
typedef unsigned long int ulong; typedef unsigned char uchar; typedef struct _hc_controller_endpoint { volatile ulong control; volatile ulong cbp; volatile ulong *next_td; volatile ulong be; }hc_ed,*phc_ed;
typedef struct _hcd_controller_endpoint { uchar error; uchar packet; volatile ulong status; hc_ed hced; }hcd_ed,*phcd_ed;
int main(void) { int i; phcd_ed ed,trace; for (i=0;i<8;i++) { ed = malloc(sizeof(hcd_ed)); if(ed != NULL) { ed->hced.next_td =&(ed->hced); ed->status =(ulong) &(ed->hced); } // i want to have address in same location. //does there any other way to implement same logic }
Exactly why do you think that you have to "deal with this problem"?
If you do need to use a pointer to a generic type, the language standard has the void pointer type.
And never ever assume that it is ok to convert between pointer types - all pointers are not equal. They can have different size. They can have different alignment requirements. They can be partially predefined - fixed to only be able to reach objects in a specific memory range.
Another thing: Please format the code according to the instructions, so that we may read it. And check the preview before posting.
