hello; i m implementing temerature display on lcd.
i m using c8051f020 ic which has inbuilt adc.
i m using 4051 mux for selection of temperature from various sources (eg:temperature of bath, jar etc). output of mux is given to adc of microcontroller through amplifier.
my code of selection of mux is working fine, i can see waveforms on scope.
i select the mux and give delay and after that i read adc.
delay given is 64msec. my output (display on lcd) is correct with 1 mux working at a time.
but when all mux are working simultaneously that time output is not as expected.
i tried to reduce as well as increase the delay but the output is still incorrect
i m using total 4 mux of 4051.
selection of the mux is done through port pin of microcontroller, and my selection is correct because output is correct with one mux working at a time.
problem is with all mux working together.
pls, guide me thank u all
you are waiting 64 milliseconds or 64 microseconds? one being very long and the other ???. Read the data sheet to find the settling time for the mux an the A2D
