overlay
we are working on a C51 project using code banking with 2 code banks(105k code)
This is the map file generated for my compiled project...
            TYPE    BASE      LENGTH    RELOCATION   SEGMENT NAME
            * * * * * * *   D A T A   M E M O R Y   * * * * * * *
            REG     0000H     0008H     ABSOLUTE     "REG BANK 0" //for main code
            REG     0008H     0008H     ABSOLUTE     "REG BANK 1" //Timer 0 ISR
            REG     0010H     0008H     ABSOLUTE     "REG BANK 2" //Kernel functions
            REG     0018H     0008H     ABSOLUTE     "REG BANK 3" //Serial ISR
            DATA    0020H     0008H     BIT_ADDR     ?BA?MIC40
            DATA    0028H     0001H     BIT_ADDR     ?BA?LINE40
            BIT     0029H.0   0000H.7   UNIT         ?BI?MIC40
                    0029H.7   0006H.1                *** GAP ***
            DATA    0030H     001FH     UNIT         _DATA_GROUP_
            DATA    004FH     0012H     UNIT         ?DT?MIC40
            IDATA   0061H     0001H     UNIT         ?ID?LINE40
            IDATA   0062H     0001H     UNIT         ?STACK
When I cross-checked the allocation of local variables in this _DATA_GROUP_ overlay range for registers usage (R0 - R7 in reg bank 0), the compiler used each register memory location for 30-35 local variables storage as shown:
            D:0001H         SYMBOL        lid
            D:0001H         SYMBOL        dt
            D:0001H         SYMBOL        m
            D:0001H         SYMBOL        tof
            D:0001H         SYMBOL        hold_lid
            D:0001H         SYMBOL        i
            D:0001H         SYMBOL        string
            D:0001H         SYMBOL        at
            D:0001H         SYMBOL        j
            D:0001H         SYMBOL        tid
            D:0001H         SYMBOL        ev
            D:0001H         SYMBOL        dtmf
            D:0001H         SYMBOL        rid
            D:0001H         SYMBOL        i
            D:0001H         SYMBOL        lid
            D:0001H         SYMBOL        sig
            D:0001H         SYMBOL        ocall
Is this reliable for me to trust the optimization done by the compiler? I am facing some data corruption and wrong operations in my project. What is the better way to decrease this overlay process at the cost of losing code as well as xdata space?
Consider the following code:
extern void runLineManager(unsigned char volatile); //external function prototype
void runLineManager(unsigned char volatile i)
                while(1)
                //      piece of code
Q: Is it necessary to include 'volatile' in function prototype also?
Please advise..
  • volatile is an attribute for variables, since it is a request that the variable may never be cached.
    The processor does not have a "normal" stack for storing auto variables, so the compiler/linker just have to analyse the call tree and figure out a mapping of auto variables to static locations.
    Do you have any recursive functions, or functions that are called both from interrupt handlers and from the normal code? Have you specified that these functions are reentrant? If not, the you may get data corruption since static variables does not work with multiple concurrently active instances of the same function.
  • Is this reliable for me to trust the optimization done by the compiler?
    Usually, yes. The compiler is merely placing local variables in registers that do not need to be assigned actual data memory (because their lifetime/scope is too limited).
    Before suspecting the optimizer, there are other, much more likely suspects for data corruption.
    Keywords should be in the prototype and the declaration. However, having a volatile function argument is very, very unusual and, ultimately, does not make sense.
