Hello, I am using timer 0 for generating 20msec interrupts, and Timer 1 as a baud rate generator. Now, I require Timer 2 in my project. So, I had studied the pdf's of Phillips 89C52X2 and started writing code as described below. if I need timer 2 in auto-reload mode in up-counting timer style. I need to toggle test led every 1 sec, which is working fine using Timer 0. But, it is not working if I use Timer 2. I need a solution
Please advise.
############## PART OF MY PROJECT CODE ################### unsigned int volatile time_keeper; void serialInit(void) { IE = 0; /* disable the interrupts */ RI=0; //serial port receiver and trans meter is TI=0; T2CON = 0x04; T2MOD = 0x02; TH2 = 0XB8; //load timer 2 for generating 20 msec delay TL2 = 0X00; ET2=1; //enable timer 2 interrupt RCAP2L = 0X00; RCAP2H = 0XB8; TR2=1; //run the timer 2 EA=1; //enable global interrupt flag } void onTimerISR(void)interrupt 5 using 1 { EA = 0; TR2 = 0; TH2 = 0xB8; TL2 = 0x00; TR2 = 1; time_keeper++; //incrementing the timer on every //interruptso we can have delay in // multiples of 20msec if(!(time_keeper%50)) test_led = ~test_led; // test led toggling every 1 second ET2=1; EA=1; //enable Interrupt } void main(void) { time_keeper = 0; serialInit(); demonTask(); } ############## PART OF MY PROJECT CODE ###################
are you optimizing code ??????
i tryed and got errors
Yes, at level 9.
try leval 8
i tryed the code but it do not copmile!!!!!!
you fix error first please??????????????????
Fix error as in "code is broken" or fix errors as in "############## PART OF MY PROJECT CODE ###################"?
