Hi im having a problem with my MCB900 board. The program i am trying to run on it will not work correctly unless the board is connected to the pc via the serial connection. Is this a grounding issue and if so how do i fix it?
I haven't checked the MCB900 board, but it isn't unlikely that it is similar to other Keil boards.
Do you have any straps to control if the serial port handshake signals should control the reset line for the processor, or if the processor should enter programming mode?
Yes, the MCB900 can use the serial port handshake signals to control the reset line for the processor - for downloading.
