Problem passing nested struct with pointer on the stack
The following code (part of a simple GUI running on a 251 platform with an LCD) attempts to pass a struct which is a member of another struct on the stack. A pointer to the container struct is dereferenced using the '->' operator. The call to DrawRect below is supposed to pass certain members of the WindowContext struct, namely two ScreenPoint structs and a byte. Instead the compiler appears to be incorrectly passing the entire WindowContext struct on the stack, and therefore the DrawRect routine that receives the faulty parameters becomes hopelessly confused.
What is going on here? (Using C251 4.00) Thanks...
struct ScreenPoint {
        unsigned char x;
        unsigned char y;
typedef struct ScreenPoint SCREENPT;
typedef struct ScreenPoint SCREENSZ;
struct WindowContext {
        SCREENPT OrgPt;
        SCREENSZ TotalSz;
        unsigned char BorderColor;
        /*Etc...*/
typedef struct WindowContext *WinPtr;
void DrawRect(SCREENPT Org, SCREENSZ Sz, unsigned char Color) reentrant;
TestFunction(WinPtr pWin) reentrant
DrawRect(pWin->OrgPt, pWin->TotalSz, pWin->BorderColor);
  • I cannot tell about C251 V4.00, but with V4.53 which is the current version things are looking good:
    C251 COMPILER V4.53d, COMPILATION OF MODULE x
    OBJECT MODULE PLACED IN x.OBJ
    COMPILER INVOKED BY: C:\Keil\C251\Bin\C251.exe x.c CODE
    stmt  level    source
        1          struct ScreenPoint {
        2            unsigned char x;
        3            unsigned char y;
        4          };
        5
        6          typedef struct ScreenPoint SCREENPT;
        7          typedef struct ScreenPoint SCREENSZ;
        8
        9          struct WindowContext {
       10            SCREENPT OrgPt;
       11            SCREENSZ TotalSz;
       12            unsigned char BorderColor;
       13            unsigned char etc[256];  // Etc.
       14          };
       15          typedef struct WindowContext *WinPtr;
       16
       17          void DrawRect(SCREENPT Org, SCREENSZ Sz, unsigned char Color) reentrant;
       18
       19          TestFunction(WinPtr pWin) reentrant  {
       20   1        DrawRect (pWin->OrgPt, pWin->TotalSz, pWin->BorderColor);
       21   1      }
    ASSEMBLY LISTING OF GENERATED OBJECT CODE
    ;       FUNCTION TestFunction?_ (BEGIN)
                                                    ; SOURCE LINE # 19
    000000 7D23           MOV      WR4,WR6
    ;---- Variable 'pWin' assigned to Register 'WR4' ----
                                                    ; SOURCE LINE # 20
    000002 7D02           MOV      WR0,WR4
    000004 0B05           INC      WR0,#02H
    000006 7E09B0         MOV      R11,@WR0         ; A=R11
    000009 CAB8           PUSH     R11              ; A=R11
    00000B 0B04           INC      WR0,#01H
    00000D 7E09B0         MOV      R11,@WR0         ; A=R11
    000010 CAB8           PUSH     R11              ; A=R11
    000012 7D02           MOV      WR0,WR4
    000014 7E09B0         MOV      R11,@WR0         ; A=R11
    000017 CAB8           PUSH     R11              ; A=R11
    000019 0B04           INC      WR0,#01H
    00001B 7E09B0         MOV      R11,@WR0         ; A=R11
    00001E CAB8           PUSH     R11              ; A=R11
    000020 09B20004       MOV      R11,@WR4+0x4     ; A=R11
    000024 120000      E  LCALL    DrawRect?_
    000027 1BFE           DEC      DR60,#04H
                                                    ; SOURCE LINE # 21
    000029 22             RET
    ;       FUNCTION TestFunction?_ (END)
Reply Children
