C164ci Simulation - Show CAPCOM pin toggling in Logig Analyzer
is it possible for the C164ci target in simulation mode to make the pin toggling of the CAPCOM output visible inside the Logic Analyzer (PK-166)?
I am using the CAPCOM6 in Edge Aligned mode, cnfigured for PWM usage. I would like to debug the output signalCOUT60 (P1L.1) and COUT61 (P1L.3) using the Logic Analyzer.
/* PWM0 and PWM1 signal frequency configuration */
D_PWM1 = 1;
D_PWM2 = 1;
/* Configuration of the PWM outputs */
CC6MSEL = 0x0022;
/* 5V -> 10bits */
CTCON = 0x001C;
/* 10230 = 100% full scale */
T12P = 10230;
T12OF = 0;
Thank you in advance for any hints or experiences,
Sammy
  • Assuming you have
    #define D_PWM1 CC60
    #define D_PWM2 CC61
    I would also change latching of the period and starting of T12.
      D_PWM1 = 1;
      D_PWM2 = 1;
      CC6MSEL = 0x0022;
      T12P = 10230;
      T12OF = 0;
      /* 5V -> 10bits */
      CTCON = 0x001C;
    Then you need to configure two pins in the "Setup Logic Analyzer" screen.
    For one:
    Current Logic Analyzer Signals: PORTL1 -> Bit -> And Mask 2 -> Shift Right 1
    For the other
    For one:
    Current Logic Analyzer Signals: PORTL1 -> Bit -> And Mask 8 -> Shift Right 3
    Hope this helps
  • Assuming you have
    #define D_PWM1 CC60
    #define D_PWM2 CC61
      D_PWM1 = 1;
      D_PWM2 = 1;
      CC6MSEL = 0x0022;
      T12P = 10230;
      T12OF = 0;
      /* 5V -> 10bits */
      CTCON = 0x001C;
    For one:
    For the other
    For one:
    Hope this helps
