Trouble in "SWITCH" case
Dear all
iam having problem with SWITCH case
                switch(aaa)
                case '1':
                        LIGHT=1;
                        printf("Light On\n");
                        break;
                case '2':
                        LIGHT=0;
                        printf("Light Off\n");
                        break;
                case '3':
                        printf("Unknown Command\n");
                        break;
                default:
                        printf("New Command\n");
                        break;
this code is running in the uvision simulator well fine.
but after compiling its not working with the chip.
same code after removing "default" tag is working with simulator as well as chip fine.
                switch(aaa)
                case '1':
                        LIGHT=1;
                        break;
                case '2':
                        LIGHT=0;
                        break;
                case '3':
                        break;
is there any "Target setting" i need to change?
iam using
On chip ROM - Enabled
X-Tall - 11.0592
Memory Model - Small
Code Rom Size - Large
Operating System - None
and in "C51" Option
Level - 8 common tail merging
Emphasis - Favor Execution speed
Compiler control string - BROWSE DEBUG OBJECTEXTEND
thanks in advance.
