I have any Problems with my Timer Interrupt I use GPT1 but it doesn't work correctly. I'm trying to implement a 1ms Timer, but it doesn't work.
Has anyone a sample for a 1ms or a 10ms second Timer on GPT1 Timer T3
Thanks for any help
Best regards RAKO
try this:
#include <reg167.h> #include <intrins.h> static unsigned long volatile timer_tick = 0UL; static void timer3_irq (void) interrupt T3INT = 35 { timer_tick++; } void timer3_setup (unsigned int ticks_per_sec) { unsigned int reload; unsigned long frequency = 2500000; unsigned int prescale; for (prescale = 0; prescale < 8; prescale++) { if ((frequency / ticks_per_sec) <= 65535) break; frequency /= 2; } reload = frequency / ticks_per_sec; T3CON = 0x0080; /* 2.5MHz, Timer Mode, Count Down */ T3CON |= prescale; T2CON = 0x0027; /* Setup T2 for reload operation on any T3OTL */ T2 = reload; /* Reload for T3 */ T3 = reload; /* Start T3 with proper reload */ T3IC = 0x0044; /* Timer 3 interrupt enabled, Level 1 */ T3R = 1; /* Start Timer */ IEN = 1; /* Enable Interrupts / } void timer3_delay (unsigned long ticks) { unsigned long start_tick; unsigned long timer_tick_copy; _atomic_ (0); /* start un-interruptable code */ start_tick = timer_tick_copy; _endatomic_ (); /* end un-interruptable code */ while (1) { _atomic_ (0); /* start un-interruptable code */ timer_tick_copy = timer_tick; _endatomic_ (); /* end un-interruptable code */ if ((timer_tick_copy - start_tick) > ticks) break; } } void main (void) { DP7 = 0x01; /* Setup P7.0 for output */ ODP7 = 0x01; /* Setup P7.0 for open-drain */ timer3_setup (1000); /* Setup timer for 1000Hz operation */ while (1) { timer3_delay (100); /* Wait 0.10 seconds */ P7 |= 0x01; /* Turn on P7.0 */ timer3_delay (100); /* Wait 0.10 seconds */ P7 &= ~0x01; /* Turn off P7.0 */ } }
