ETHERNET_LPC2378 hangs
Hi all
I am using LPC2378 processor and trying to initialize the ethernet ...i got the ethernet code from the net for MCB2300 board.
my LPC2378 is running on 16MHz crystal. and i am using DM9161 PHY layer which is different from the dev board of DP83848 chip.
I am using keil compiler for debugging the code but when i am trying to initialize the LPC internal register for ethernet .
   MAC1 = 0xCF00 ; /*soft resets all MAC internal modules*/
then after some delay
MAC_MAC1 = 0x0;         /* deassert all of the above soft resets in MAC1 */
the problem occures when i de assert the MAC1 register the debug stops and indicates an error saying "debug cannot stop the ARM module " agter which i am unable to debug the code .
if the ethernet init function is blocked and debugged ,its working fine .
The thing i am unable to understand is the same code is working for me on the dev board MCB2300 boad without any problem.....so wt might be problem with my LPC board .
has any one came accross this problem ....plz provode me with the solution ..
Regards
Suresh
