use GNU compiler in Keil, code size limitiation
I am using GNU compiler with Evaluation Version of the µVision IDE. From Keil website it says: The GNU ARM tools (compiler, assembler, and so on) that are provided are not limited or restricted in any way. Does it mean I can compile, debug and run simulation without code size constrain? But the result is that I could not debug and run simulation. and I also could not download it to the target board.
thank you for your help!
