I use an KitCon c515c and KItCon-can with LCD.My problem is that i can't display nothing on display.The DB0-DB7 on LCD are on Do-D7 on KitCan,and control signal are on A6-A9 on Kitcan. Help me.Sorry my language.
"nothing on display" Did you make sure Initialization of LCD is Correctly and make sure that you are sending ASCI Value or not?
Please me the way ur sending the Data ?
the problems is that i take the datasheeat on internet about my lcd(BT21605)and there don't write nothing about Initialization or somthing else.other problem is that i never use lcd, i use 7 segments, or other this part ,never lcd, and i don't now exactly what i must do it to display on LCD .i use an c complier and i don't now what function to use.i found on internet exemple who use fprintf or printf but nothing to show how to use this function.Thank for any help.
which chip is in the LCD module.
if it is one of the more common ones (have yet to see anything else), someone will lead you to a datasheet for a LCD that uses the same chip (= identical commands)
